Vtec engagement questions
I got a GSR swap in my tegy. My mods now are CTR pulley, 11.5 lbs flywheel, Competition stage four 6 puck clutch, skunk2 intake manifold, Hondata heat shield gasket, ram-air intake, and cat back exhaust.
It is running off a p28 chipped with Crome.
I noticed my vtec is engages at 6000 RPM. I thought that was kind of late since my redline is 8200. Only 2000 RPM of Vtec?
Is this when a stock P72 engages?
I talked to my tuner and he said I could lower it.
I was thinking about dropping it to 4800 RPM.
I know oil pressure needs to be high for everything to run smooth and I have heard lowering the Vtec engagement can actually make you lose power?
I was going to also start using Hamp oil filters just for a little piece of mind as well . . . . .
4400 rpm is stock vtec engagement point for a 1998 Gsr with the stock obd2 p72 ecu. Personally its a little low for daily driving. I converted to obd1 and I had it set at 4700 rpm just to be different, but it is more manageable for daily driving. I always found that vtec would engage right before i would shift making the car sound very odd. Now its much better.
4400rpm engagement, butterflies open at 5800 rpm on a stock p72 head using stock p72 computer.
Check with whoever tuned the car, since they are probably the ones who programmed it to kick in that late. Usually with a skunk2 manifold you would put it up in the 5200-5800 range according to how modified the engine and fuel system are.
