Transmission & Drivetrain Gearboxes, Differentials, Clutches
y1 lsd into ys1 case
Old Oct 10, 2010 | 08:07 AM
spyke11's Avatar
Default y1 lsd into ys1 case
Sorry if this has been answered before, but ive been searching this site, and many others like it, and i still have'nt been able to find a definate answer yet. is it at all possible to fit a Y1 lsd into a 93 usdm gsr case, and if so, what needs to be done. Thanks in advance.
Old Oct 10, 2010 | 08:39 AM
David @ Synchrotech's Avatar
Default Re: y1 lsd into ys1 case
The Y1 uses a viscous type LSD with the ring gear as an integral part. The matching countershaft needs to be used with it and will not fit in the YS1 due to the different splines.
Old Oct 10, 2010 | 09:15 AM
Honda Bull's Avatar
Yeah. The differential housing itself can fit, but due to the need for the 15-bolt ring gear, the matching countershaft isn't going to work with the 92+ gears.
Old Oct 17, 2010 | 01:40 PM
spyke11's Avatar
Thanks for the speedy reply guys. Is it safe to say than, that both y1, and ys1 trannys are not compatible with any parts between each of them. I guess I ll have to try to sell one of them seeing as i have a one of each in cable version, and i wanted to mix the 2 to make one good one!!
Old Oct 17, 2010 | 04:52 PM
94EG8's Avatar
Seagull Management
They aren't compatible with each other, the YS1 is the better tranny (basically a hydro tranny in a cable case)
Old Oct 20, 2010 | 08:10 AM
spyke11's Avatar
Is it possible for a y1 diff to have the 4.4 final drive? i just did the calculations between the 2 gears, and those are the results. I always thought the final for a y1 was 4.2. There are only 10 bolts on the diff carrier, so im pretty sure its a y1 diff. Also,do ys1 cable and B16A hydro tranny parts mix and match?? My buddy has the hydro, so, if possible, i may take his tranny, and make one good ys1. Thanks again guys. Can i please get some help with this ??
Junkyard2000
17
Dec 20, 2005 01:30 PM
NixTEG
Mar 15, 2004 07:38 PM
jDMJeRk
Dec 23, 2003 07:31 PM
cornholioEK
Sep 30, 2002 06:46 PM
Mazmay
13
Jun 21, 2002 12:10 PM
