timing belt question
this is what happend i did a mini me and changed the timing belt and water pump but now im not runnig a knock sensor and i have a check engine light that says that i need one does this knock sensor have anything to do with the 2ed gear not pulling good uphill ?
i didnt run a knock sensor because the y7 block didnt have one i ordered one and its in the mail but yes its was to TDC and it runs good just needs the timing adjusted i think but thats what im asking is if the knock sensor effects the timing in any why like if i were to get it would my car get any faster in 2ed gear ?
What do you think the knock sensor is for? To detect knock, right? After it sees knock, what does it do to correct it? It removes timing until the knock goes away or it reaches the limit of what it can pull. So YES, it effects timing. Will having one missing and a CEL on effect timing enough to make the car not pull a hill in second? Highly doubt it. I can pull hills in 5th in my stock EX. I think you have the timing off a tooth, perhaps more. What head did you put on the car? Y8 or Z6?
eselcarson
27
Feb 27, 2017 02:06 PM
AnAccordIsForever
Nov 13, 2007 08:31 AM
