99 civic question PLEASE HELP
Old Oct 10, 2010 | 06:58 AM
send2artem's Avatar
Default 99 civic question PLEASE HELP
i need to konw where the knock sensor is on a 99 civic hatch dx i know they dont have one i just want to know if there is like a hole for one and if so where i can find it also do i really need one? i mean what does it do?
Old Oct 10, 2010 | 01:16 PM
RyanA's Avatar
Default Re: 99 civic question PLEASE HELP
Yes, they have a hole for it. It's at the top of the block on the back side above where the oil pressure switch/sensor is. No need to put one on your stock setup; your ECU does not even support it. Honda did not feel they needed to put one on so I'd say you'll be just fine.
Old Oct 10, 2010 | 01:38 PM
send2artem's Avatar
the thing is i did a mini me swap and the check engine liight is on its saying that i need one
Old Oct 10, 2010 | 02:31 PM
RyanA's Avatar
OK, so you should add one. You omitted that you now had a VTEC head and, more than likely, a P2P ECU that requires a Knock sensor. Yes, add one.
Old Oct 10, 2010 | 05:26 PM
Jimmy's Avatar
Global Moderator
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Hector Rentas
Jun 4, 2018 07:57 AM
send2artem
Oct 12, 2010 06:03 AM
hondaboynky
May 7, 2010 11:49 AM
Crackback
Sep 7, 2006 05:24 PM
