Sedan cluster fit coupe ? 92-95 civic
I have an integra cluster in my car (std one),and i am putting the car back to auto.I got a 4 door lined up and i was wondering will the 4 door(auto) cluster fit the 2 door dash?
Biggest thing you wanna be sure you have is the correct ECU. 5 speed and auto use different ECU's and it will effect your cluster readings.
I was told it effects the shifting of the Auto if your using a 5 speed ECU thus will cause the speedo to read differently.
The only thing to notice is using the auto cluster in a standard you will have one plug that won't be filled, just so you don't freak out thinking it won't work. the one plug is for the PRND.
bayron
Jul 25, 2008 09:47 AM
bayron
Jul 14, 2008 08:50 PM
