problem on my EG sedan B18C
hello guys..
my civic-eg installed wif 94's b18c type Si engine.
after 3 year running wif this engine, i finally upgrade it with this spec:
S90 70mm Throttle body, skunk2 intake manifold, PCT camshaft + valve spring, PCT piston, ACL race bearing, HKS 4.2kg flywheel, trinity clutch set, 4-1 header..rechipped ecu, vafc, Ultra silicone 8mm plug cable, adjustable cam gear.
but...there is a few problem.
01-when i start the engine, its running like "lost compression".
(i had do the comp.block test..the result is 19)
what should i do next, help me guys...
