97 civic si clone_BUILT GSR 208hp_
I got this car at age 15 when it was completely bone stock and have worked my way up to this point. I am looking to either trade it or sell but will not take a hit on it as it is a very well built car. I am looking to get $9500 or trade
GENERAL INFO
*innovative mounts with stiff bushings(no marshmellow bushings)
*all mounts and brackets were powdercoated black
* si front end and bumper
*Pioneer Deck
*Custom clutch line that runes behind the firewall, through the frame and to the slave cyl.
*Tucked brake lines(all mounted and riveted) kept heat
-chasebays coated brakelines with A/N fittings
-willwood master with a booster delete plate(stiff pedal, stops great)
-Integra prop valve
*integra brakes all the way around
*new pads, rotors (anything brake related has pretty much been replaced)
SUSPENSION
*Koni Yellow/Ground Control (bought new, great condition)
*Rota flashbacks Falken 912 tires
*Extended top hats
*ASR subframe brace(black)
*function 7 black lca's
*ASR swaybar
*blox camber/toe kits(everything)
*new wheel bearings
*extended studs
*buddyclub lugnuts
_A lot of suspension and brake work has been replaced and upgraded, handles amazing_
MOTOR
208hp 150tq
(ON LOW COMPRESSION! and you only have to rev to 7700 to make this power)
*B18c1 (81.5 mm)
*type R trans(LSD)
*ls crank
*Eagle rods with upgraded bolts
*mahle 10.5.1 pistons
*all new waterpump,timingbelt,oilpump,gaskets, etc.
*supertech springs
*supertech retainers
*supertech keepers
*supertech valve seals
*supertech flat face high compression valves
*skunk2pro2 cams
*precision 580cc injectors
*new oem headgasket
*ARP headstuds
*blackworks full size aluminum radiator
*samco radiator hoses
*STR adjustable cam gears/cam cap
*Blox intake manifold(port matched to throttle body)
*Omni 70mm Throttle boddy
*aluminum catch can with black braided lines and fittings
*kiddracing replica header(2 1/2 inch collector)
*full stainless tig welded custom 3” exhaust all the way to the rear bumper with a turndown.(exhaust built for boost so it is loud now)
INTERIOR
*Bride seats (black with gradation) Replicas but are very nice
*G FORCE 5 pt harnesses with twist lock
*dash/carpet/doorpanels and all plastics are black
*Tucked fuse box(NO AIRBAGS, fusebox is in the airbag location)
*Battery relocation
*CTR cluster(amber)
*6 point rollbar(not bolted in, but comes with)
*nrg quick release
*nrg hub
*nardi suede replica wheel
i know im forgetting stuff but overall the car is very nice and i really dont have to get rid of it, just seeing whats out there and looking to start a new project.
How it all started
now on to some pictures starting with the most recent.
(the bumper with holes is no longer on the car, it has a new si bumper)
*a few motor build pictures from previous cams*
now for some that are a little older
If you need more direct shots of the car or pictures of the motor build I will be more than happy to upload them(they are on a friends computer)
GENERAL INFO
*Pioneer Deck
-Integra prop valve
SUSPENSION
*Extended top hats
*ASR swaybar
*new wheel bearings
*extended studs
*buddyclub lugnuts
MOTOR
208hp 150tq
*B18c1 (81.5 mm)
*type R trans(LSD)
*ls crank
*supertech springs
*supertech keepers
*skunk2pro2 cams
*new oem headgasket
*ARP headstuds
INTERIOR
*Battery relocation
*CTR cluster(amber)
*nrg quick release
*nrg hub
How it all started
Car ran a 12.8@ 107mph last year without the lsd trans and with different cams(was makin 190 hp, 130tq then) should run a good time now with 20 more hp and 20 more ft.lb
thanks for all the compliments just seeing whats out there
