losing oil
Old Oct 9, 2010 | 09:44 AM
Rickdogg's Avatar
Icon2 losing oil
i got a 90 ls with 200k on it its a auto i just put a new head gasket on new cat and i got it smogged it passed i have been driving it for about a week almost and i checked the oil on it today and it below the mark on the dip stick i checked for leaks i dont really see nothin theres a little white smoke when i start the car but after that it stops
Old Oct 9, 2010 | 09:53 AM
hillssol95's Avatar
Default Re: losing oil
check the oil pan gasket, and the valve cover gasket if your certain it isn't burning it. I have had a few honda's that were just slowly leaking a little out of the oil pan gasket where it meets the transmission!
Old Oct 9, 2010 | 10:18 AM
Drive 4 fun's Avatar
Why new HG? Have you owned it, or just got it? Not using oil before?
Old Oct 9, 2010 | 10:26 AM
witeda9's Avatar
its got 200k it probually needs a valve job because ur burning oil not just loosing it im suprised u passed smog burning smoke that shouldve been an automatic failure u should tune it up with adjusting the valves and then see if u still burn smoke if u are stll do a cylinder leak test
Old Oct 9, 2010 | 11:14 AM
Rickdogg's Avatar
when i got the car it had a bad headgasket on it didnt know it at the time good surprise i guess when you buy a car =p so i got a new/used head and gasket and slapped those on the car it does sound really loud like a lawn mower and my oil is black too?
Old Oct 9, 2010 | 03:33 PM
all-mtr-teg's Avatar
Really black oil immediately after an oil change is most likely bad rings. The carbon from combustion is leaking past the rings and contaminating your oil. Or another possibility, valve guides are very worn and carbon is contaminating your oil through the guides. Either way, either will need a rebuild to remedy the problem.
Old Oct 10, 2010 | 08:06 AM
Rickdogg's Avatar
damn that suck cause i just spent $400 getting it running again wat if i keep oil in it
Old Oct 10, 2010 | 08:24 AM
Speed Infliction's Avatar
You can keep adding oil if you want to do it that way until you fix it. just make sure you still change the oil every 3k or month.
Old Oct 10, 2010 | 08:36 AM
EHondaJDM's Avatar
400!?
you couldve had a whole new engine for that
Old Oct 11, 2010 | 09:41 AM
Rickdogg's Avatar
ya for registration and smog plus new cat where can i get a motor for that cheap?
Old Oct 11, 2010 | 10:09 AM
el crapitan's Avatar
with the engine running, unscrew the oil cap. is there pressure there?
you can do a leakdown to try and determine the cause of consumption
i'd probably run a compression test first though, just to see where you're at there and give you an idea of which cylinder(s) to pay attention to
big-cat
Aug 8, 2009 05:05 AM
EkFG
Mar 15, 2008 07:47 PM
Kapetan
Oct 19, 2006 08:35 AM
G3gsr
May 20, 2003 06:17 PM
c1hatch
Jul 28, 2002 07:27 PM
