Transmission & Drivetrain Gearboxes, Differentials, Clutches
opening b series trans case
Old Oct 9, 2010 | 12:52 AM
eg6nike's Avatar
Default opening b series trans case
ive gotten to the stage of releasing the c clip on the counter shaft and after prying it apart about 50 times with a pair of screw drivers i can get the counter shaft released from the clip. even after prying the casing apart about an inch and hold the c clip open it stil wont release. my next option out of frustration is the sledge hammer the **** apart so i can get the 5th gear out and swap it into another transmission...
any suggestions please?
Old Oct 9, 2010 | 06:59 AM
I B BANGGIN's Avatar
Default Re: opening b series trans case
I recomend using the correct tools...a pair of snap ring pliars would work magic. Your prob just not opening the c clip enough.
Old Oct 10, 2010 | 02:24 AM
Clerique's Avatar
Extra hands might work in this situation; while you spread the clip, let someone lift the case.
Old Oct 10, 2010 | 09:19 AM
Honda Bull's Avatar
Elevate the trans from the ground with blocks of wood. Get some needle nose pliers to open the clip. If the bearing is still stuck, have a friend take a 3/8" extension or something that will fit on the bearing between the pliers and tap on it with a hammer to dislodge it. Some can be tight at times. Usually not though. They *should* fall right down.
Old Oct 11, 2010 | 09:28 PM
eg6nike's Avatar
thanks guys after a a lil hammering and shaking it finally came loose.
nycjdmwhore
Dec 27, 2012 01:22 PM
civgt28
Apr 19, 2011 06:46 PM
turbo00EK
May 13, 2009 05:03 PM
NativeSon
Nov 26, 2008 04:56 PM
InJ3cted
Mar 1, 2006 10:24 PM
