Suspension & Brakes Theory, alignment, spring rates....
help asap!!!! drum to disk conversion help
Old Oct 8, 2010 | 11:11 PM
G-Auto*Hero's Avatar
Default help asap!!!! drum to disk conversion help
i have a 93 civic ex. its got drums but i want to put disk on the rear. off of what car would i have to pull them off and what all would i need? i now that stuff off a 94-2001 teg well fit. i can get the stuff for free but its coming off a 1996 4 door teg. does it matter that its a 4 door teg? if im able to work with that what well i need to pull off and what would i need to trade off.
Old Oct 9, 2010 | 12:17 AM
Default Re: help asap!!!! drum to disk conversion help
i need to now if the parts off that car well work his going to take the car to the junk yard on sunday
Old Oct 11, 2010 | 10:56 AM
Hooptie2's Avatar
If you can get the entire rear trailing arms, it will make things 10x easier on you. They are interchangable and your rear lower control arms from the Civic should work too. Hope this helps. Also, while you have the rear trailing arms out it would be a good idea to fund some stainless steel brake lines. Don't forget about your proportioning valve either. If you can get the one off the Integra, it work fine. Good luck
Old Oct 11, 2010 | 10:58 AM
Hooptie2's Avatar
If you can get the entire rear trailing arms, it will make things 10x easier on you. They are interchangable and your rear lower control arms from the Civic should work too. Also, while you have the rear trailing arms out it would be a good idea to find some stainless steel brake lines. Don't forget about your proportioning valve either. If you can get the one off the Integra, it work fine. Good luck, Hope this helps.
twotonecivic
Jan 18, 2007 06:54 PM
Honduh@Love
10
Sep 19, 2005 08:38 PM
cliff666
Jun 20, 2005 03:08 PM
stickywhiteEH2
Apr 15, 2004 09:03 AM
h22dc2
Aug 17, 2002 07:14 PM
