obd1 ls crx swap question
Old Oct 8, 2010 | 03:40 PM
vtecjunkie228's Avatar
Default obd1 ls crx swap question
i have a 91 crx hf with a d16z6.it has been converted to mpfi and it has an obd0 to obd1 jumper harness but the ecu is a p75 ls ecu(i did not do the swap)....ive had some problems with the trans and just put a different one in and now is leaking so i just want to swap it all....
would i be able to swap an obd1 b18b in and use my harness since its runing obd1 p75
Old Oct 8, 2010 | 04:47 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: obd1 ls crx swap question
yeah, depending on where your 4 wire O2 is now you may have to extend it but otherwise it should be fine
Old Oct 8, 2010 | 05:18 PM
sweet sounds promising anybody else?
Old Oct 9, 2010 | 05:16 AM
bumpppp
Old Oct 9, 2010 | 06:23 AM
JCB's Avatar
JCB
Yeah, you'll be fine!!!
Old Oct 9, 2010 | 10:56 AM
D16SiHatch's Avatar
yep^
check this out. should help you out with the swap
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
Old Oct 9, 2010 | 04:54 PM
thats a pretty good write up but now a lil confused on injectors i would just use obd 0 ls injectors and leave resistor box alone rite?
Old Oct 9, 2010 | 05:21 PM
zCivic's Avatar
If using OBD0 low impedence injectors use the resistor box. If anything newer higher impedence no box needed.
AJxr
Jan 15, 2007 07:18 PM
mr_hahn73
Oct 7, 2006 11:19 AM
solohatch
Jul 1, 2005 12:13 AM
rogue3221
Nov 23, 2004 11:36 AM
dpine
Jul 14, 2004 06:19 PM
