91 dx only getting 200 miles per tank??
Old Oct 8, 2010 | 02:39 PM
91ef_civic's Avatar
Default 91 dx only getting 200 miles per tank??
i have a 91 dx 5speed with a rebuilt 93 d15 engine, the car is converted to obd1 and is mpfi. the o2 sensor was chipped out of the ecu but other then that its stock. all i have on it is a CAI, im running on SI stock rims with decent tires. i seem to be only getting like 200 to a tank and its mostly highway driving. i also noticed that in the morning or when i first start the car the idel is at almost 2k, when i drive down the road a little bit it will go back down to about 800 and stay there at idel which is fine. a few other little issues im having is if i just touch the gas pedal a little the engine will rev up to like 4-5k with just a touch of the pedal??? what is the matter with my car? i know i should be getting better fuel millage then this????
Old Oct 8, 2010 | 03:23 PM
.Manny.'s Avatar
Touching My Member
Default Re: 91 dx only getting 200 miles per tank??
Unchip the ecu and let it read the O2 sensor.
Old Oct 9, 2010 | 06:34 AM
JCB's Avatar
JCB
Check your plugs to see if the car is running rich, unless you have a wideband or know someone who does... seeing that your computer is chipped I would imagine whoever did that has one. Also this may seem like a dumb question but how do you drive the car and how many miles are on it. My experience has been when breaking a engine in the fuel consumption is greater then when it's broken in.
Old Oct 9, 2010 | 11:40 AM
alex14's Avatar
the o2 sensor is what helps determine how much air/fuel to put into the chamber. Making the o2 not read is probably the issue.
Old Oct 9, 2010 | 06:15 PM
91ef_civic's Avatar
well like i said the engine is new it probably has like 5k now the plugs are a little rich but not that bad and everything is new. also its weird cause in 1st and 2nd gear the car has some power but 3-5 almost feel like the same damn gear... ie after 2nd gear the car is sloooooooow. now i know its not a vtec engine or anything like that but its sloooooooow
Old Oct 9, 2010 | 10:15 PM
.Manny.'s Avatar
Touching My Member
un-chip computer and make sure timing is correct
Old Oct 9, 2010 | 10:36 PM
jester1614's Avatar
what should i expect for gas mileage? I have an 88 dx with a d16y7 swap with a dsm turbo and an 88 si transmission?
Old Oct 9, 2010 | 11:10 PM
jester1614's Avatar
oh and its a chipped p28 ecu
egvtec
23
Dec 5, 2008 02:48 PM
grg9988
Sep 18, 2007 03:48 PM
square_1
Jul 10, 2006 07:19 AM
91civichatchCrX
Nov 22, 2005 01:54 AM
bigpumpa
Feb 4, 2004 07:59 PM
