Help 92 civic
Old Oct 8, 2010 | 01:30 PM
cubanteg16's Avatar
Default Help 92 civic
Hey I have a 92 civic hatch and while driving I hear a rubbing sound but it goes away when I turn...I do not have the wheel under lining and my tires are in perfect condition so it's not rubbing on fender...so what could it be please help... By the way it's coming from passenger front tire...thanx
Old Oct 8, 2010 | 01:39 PM
93egSLEEPER's Avatar
Default Re: Help 92 civic
Does it matter which way you turn? What size tires are you running? Is your car lowered?
Old Oct 8, 2010 | 02:12 PM
cubanteg16's Avatar
It doesn't matter which way I turn it never makes the noise only when traveling straight...and yes car is lowered...and it's on the regular stock stealies...I believe it's 195/65r14
Old Oct 8, 2010 | 02:20 PM
fv8s's Avatar
control arms?
Old Oct 8, 2010 | 02:23 PM
cubanteg16's Avatar
What about control arms??
Old Oct 8, 2010 | 02:24 PM
fv8s's Avatar
how lowered is it? its possible that your control arms are touching/ rubbing inside the inner shock tower
Old Oct 8, 2010 | 02:28 PM
xJDMB16x's Avatar
It could also be your wheel bearing or your axle
Old Oct 8, 2010 | 02:31 PM
cubanteg16's Avatar
It's not that low plus they been same height for some time now this noise is very recent outta no where
Old Oct 8, 2010 | 02:33 PM
fv8s's Avatar
a wheel bearing would be a hum and an axle would be more of a click. he should check his boots for tears or any unusual signs of wear on the axles. check all your suspension components while you are under there and you will find it
Old Oct 8, 2010 | 02:42 PM
cubanteg16's Avatar
Axel is brand new too but ok thanx I'll check...is there any specific way to check to see if wheel bearing is bad
Old Oct 8, 2010 | 03:04 PM
fv8s's Avatar
i usually play it by ear, but you can possibly jack the car up and spin the wheel or turn it to see if you hear that noise.
Old Oct 8, 2010 | 03:08 PM
cubanteg16's Avatar
Thanks alot
Old Oct 8, 2010 | 04:20 PM
Checking the wheel bearing for tightness is key too. grab the tire on top and bottom and try to wiggle it back and forth (like a loose tooth) if there is play the bearing is bad.
coco718
Honda Civic (2001 - 2005)
12
Oct 28, 2011 09:27 PM
svtford4x4
Mar 14, 2011 03:12 AM
jonnyt1130
Transmission & Drivetrain
May 12, 2010 03:40 PM
hondazccivic
27
Sep 12, 2008 06:42 PM
