Driving me crazy!!!!
So I bought my first ef to use a a daily driver while I work on my gsr but anyway problem just started when the weather got wet and colder I live i'n Washington so I go out to start it i'n the morning and it won't start if I wait till till later i'n the day(after it gets warmer and dryer) it stars right up. Weird huh maybe bad dizzy? Getting moisture i'n it? I don't know what to check first? Any and all help would be appreciated thanks for looking please help!!!
I live in Tacoma but i'm mpfi in the morning it's always a hard start but if I crank it for what seems like 5 minutes really like 30 seconds it starts and main relay would cause the opposite not starting when it's warm out also check spark plugs
Your firing order is wrong those things wouldn't cause that unless the screw came out of the rotor lol that happened to me I didn't figure it out for like a days and half and some searching on google lol but if you crank it long enough it will start
Ok so it started right up this morning but still has a real bad miss when I'm trying to excelerate. I'm thinking it's the junk auto lite spark plugs my girl got me I went to gap them at .040 and the were already gaped at some where over .046. What do you think I know ngk says gap there's at .044 but these aren't ngk. Autolite junk pre gaped.? I think I'm gonna put the old ones back i'n start there and see what happens
Ok just drove it. Runs better but still a slight miss/ hesitation so I went to adjust timing again and stripped the dang bolt so I will have to do this after work when I get home I'll keep you posted.
Most plugs nowadays come pre-gapped at the correct gap for that type of plug. Usually a main relay problem can be kinda random as well. If it starts up fine sometimes then doesn't start other times regardless of time of day, you'll know for sure. You can also listen for the MR click when you turn the key.
What kind of gas have you been running in it? Perhaps running a higher octane for a couple weeks to try and help clean stuff up a bit would help?
nismogrendel
Apr 24, 2010 01:43 AM
Slow as piss
Oct 4, 2005 02:10 PM
