High idle and semi sputter
Old Oct 6, 2010 | 10:13 AM
Egreyes's Avatar
Default High idle and semi sputter
I was currently on here requiring help to get my car to start, quick run down. Had oil in the plug hole so my car wasn't starting, replaced the tube seals and spark plugs and it fires right up now, but now when i start it it idles at alittle under 2k and has a little sputter to it. Any idea's? My plugs could be gaped wrong would cause it?
Old Oct 6, 2010 | 10:22 AM
redef90si's Avatar
Default Re: High idle and semi sputter
could be a vacuum leak,dirty IACV(IDLE AIR CONTROL VALVE) how's your coolant/oil level(make sure there topped up to the rights levels,best of luck;Matt
boost4life1
May 15, 2012 08:52 PM
JayDL
May 13, 2011 04:00 AM
dointhemzs
Sep 7, 2008 07:09 PM
92ehatch
Jan 4, 2006 02:35 PM
Thanks knightsport!
Apr 9, 2005 02:50 PM
