wiring help
ok i have started on my tuck harness and i need help identifying some plugs. i have seareched here and found no diagrams. some help would be appreciated. thanks.
here are some pics to help.
this plug has a black wire and a yellow wire with a green stripe
this one is green with white and red with yellow wires.
red with white and white wires
blue and black with yellow wires
single yellow with green stripe
single white shielded wire
red/blue, yellow/white, green/white wires
single yellow with red stripe
green/black and yellow/white
thanks for your help.
comon people someone has got to know what some are for, i found a couple.
IAT- GREEN/WHITE AND RED/YELLOW
TPS - GREEN/WHITE, YELOOW/WHITE, AND RED/BLUE
thats what i found so far.
ok so with some more resaerch i found most of the plugs, but i still dont know about the knock sensor. is it a one or 2 wire plug? and what is this white wire that is sheilded?
is the knock sensor on the engine harness or the conversion harness?
1.thermo switch
2.iat
3.thermo sensor
4.eacv
5.oil pressure
6.dizzy wire I believe as it is the only wires that are shilded
7.tps
8.temp sending unit
9.reverse switch
Your harness looks like a spider web btw...
yeah they hacked the harness pretty good but i recut and soldered and heat shrunk all of the connections so its gtg. yeah the new o2 wires are on the conversion harness but is the 1 wire o2 sensor on the engine harness? if it is then i can just depin it from the plug.
LuckyStrike90
Feb 15, 2018 01:42 PM
Nerologic
Jul 11, 2004 03:54 PM
