Suspension & Brakes Theory, alignment, spring rates....
92 eg hatch no brakes
Old Oct 5, 2010 | 07:45 PM
ray257's Avatar
Default 92 eg hatch no brakes
i was driving my car and the brakes just stopped working. you can push the peddle all the way to the floor and and nothing happens, and my brake light is on in the cluster. the master cylinder has brake fluid..... any ideas
Old Oct 6, 2010 | 07:13 AM
Gekko's Avatar
Default Re: 92 eg hatch no brakes
I'd check all four corners to ensure you're not leaking fluid but most likely if the pedal can go to the floor with no resistance then your master cylinder seals are bad. Replacing the master cylinder isn't a big deal, search on here and I'm sure you can find a good writeup.
Old Oct 7, 2010 | 07:56 AM
ray257's Avatar
thanks alot I took the wheels off and inspected the calipers and i found that the right front caliper lost a pad causing the caliper piston to come out and leak all of the fluid out.. does anyone sell a caliper rebuild kit.
Old Oct 7, 2010 | 09:11 AM
Gekko's Avatar
I rebuilt the front calipers on my Integra about a year ago. I bought new caliper piston rubber seals/boots from http://www.rockauto.com/
You can use compressed air to pop out the caliper pistons so you can replace the rubber parts.
pair8hd
Oct 12, 2011 07:35 PM
WhiteOnRice
May 24, 2010 12:36 AM
tyro
13
Jul 20, 2006 08:08 PM
makelove2hondas
May 28, 2006 12:13 PM
SneezinCD5
Nov 20, 2005 03:01 PM
