welding radiator support
Old Oct 5, 2010 | 01:25 PM
mikeymcm's Avatar
Default welding radiator support
This is a noob question but I see people welding in cars all the time. roll cages etc. and I always wonder.
I have to tack on a couple of pieces to the radiator support for the radiator to sit on. My question is, do I have to remove the battery or fuse boxes or anything like that? i've always been confused as to how welding parts of a car affects the cars electrical system.
thanks guys.
Old Oct 5, 2010 | 03:02 PM
angel_i's Avatar
Default Re: welding radiator support
Would it burn up the PCM?
Old Oct 5, 2010 | 03:10 PM
welfarepc's Avatar
just attach your ground to a good clean piece of steel and start welding.
nothing bad has ever happened to me or my car doing it like this.
Old Oct 5, 2010 | 03:14 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Disconnect the Neg. terminal on the battery.
Old Oct 5, 2010 | 04:38 PM
HamiltonRex's Avatar
I always disconnect my ECU on my talon, but my ECU is damn expensive and im a bit **** about it. I disconnected the negative as well,
I've welded on other vehicles to do quick things when people are in a rush and don't bother disconnecting the battery or ecu, never seems to cause an issue.
Old Oct 5, 2010 | 05:05 PM
2k.civic.si's Avatar
just pull the ecu out for safe measure.
Old Oct 5, 2010 | 06:18 PM
mikeymcm's Avatar
Thanks for the info guys.
I'm paranoid so I'll probably just undo everything. Just wanted to what everyone else does.
boostedef123
Mar 21, 2012 04:04 PM
chase7687
Feb 24, 2010 06:44 PM
vectorsolid
Jul 30, 2009 05:42 PM
garados
Welding / Fabrication
Jun 5, 2008 08:05 PM
