welding radiator support
This is a noob question but I see people welding in cars all the time. roll cages etc. and I always wonder.
I have to tack on a couple of pieces to the radiator support for the radiator to sit on. My question is, do I have to remove the battery or fuse boxes or anything like that? i've always been confused as to how welding parts of a car affects the cars electrical system. thanks guys. |
Re: welding radiator support
Would it burn up the PCM?
just attach your ground to a good clean piece of steel and start welding.
nothing bad has ever happened to me or my car doing it like this. |
Disconnect the Neg. terminal on the battery.
I always disconnect my ECU on my talon, but my ECU is damn expensive and im a bit anal about it. I disconnected the negative as well,
I've welded on other vehicles to do quick things when people are in a rush and don't bother disconnecting the battery or ecu, never seems to cause an issue. |
just pull the ecu out for safe measure.
Thanks for the info guys.
I'm paranoid so I'll probably just undo everything. Just wanted to what everyone else does. |
