transmission on 90 accord
Old Oct 4, 2010 | 09:10 PM
xpsychojasonx's Avatar
Default transmission on 90 accord
how hard is it to change out the trans fluid and filter?
cuz ive never done it to an import car(first one).. ive always owned and worked on GMs
Old Oct 5, 2010 | 04:27 AM
market525's Avatar
Default Re: transmission on 90 accord
$20 bucks well spent ... go to your nearest auto parts store and buy a Haynes manual for your car if you intend to do much work on it yourself.
In answer to your question, the AFT change is easy on this car. You'll need basic hand tools, and a long funnel. Check your manual, but I think Accord's of this era can use Dextron fluid, rather than the Honda Z1 fluid?
Buy the manual ... it will show pictures & give good detail.
Old Oct 5, 2010 | 05:37 AM
jdadams12's Avatar
You cannot change the filter - there is a filter/screen, but it is internal.
There is a drain plug that uses a 3/8" drive to remove. Drain the fluid and then refill with the correct amount - this will not get all of the fluid out, rather just the fluid in the pan. Do this twice (after a short drive) and you will get out about 75-80% of the old fluid. A third time gets the percentage up into the 90% range. I always change hot fluid.
I would use synthetic dextron/mercron III rather than the Honda Z1. The Z1 is full of friction modifiers to cause clutch slippage for smother shifts - the dex/merc III offers firmer shifts for less wear.
This job is no harder than changing oil.
Old Oct 6, 2010 | 06:18 AM
ok thanks guys... i can get that stuff kinda cheap, cuz i work at an auto parts store.. but i just deliver the parts to different shops
Old Oct 16, 2010 | 01:35 PM
how many quarts does it take
Old Oct 16, 2010 | 08:25 PM
JamesB1985's Avatar
2.50 Quarts (2.4L)
Old Oct 18, 2010 | 05:52 AM
psychojason's Avatar
Originally Posted by JamesB1985
2.50 Quarts (2.4L)
its got a 2.2
Old Oct 18, 2010 | 05:55 AM
a friend told me 3-4 qts
dk199160
Oct 23, 2015 11:54 AM
hometheaterman
Jan 31, 2008 04:37 PM
sharpescalade
May 31, 2007 12:31 PM
businessmanph
Acura TL, RL & ZDX
Sep 8, 2006 01:57 PM
h4x
15
Apr 4, 2006 08:07 AM
