Ice Box and Valve cover
Old Oct 4, 2010 | 06:22 AM
seerx's Avatar
Default Ice Box and Valve cover
Just wanted to post up some pictures of what my friend and I built for my hatch. My friend did all the welding I designed, cut and bent. For the valve cover I just made a template and he took it over from there. I can not thank him enough for the help.
Old Oct 4, 2010 | 06:34 PM
I.C.C.'s Avatar
Default Re: Ice Box and Valve cover
That valve cover looks pretty sweet! Any more shots of the icebox completed??
Old Oct 5, 2010 | 06:50 AM
seerx's Avatar
Sorry not yet. When I complete it I will post some more pics up
Old Oct 5, 2010 | 04:49 PM
HamiltonRex's Avatar
I would like to see the lid design of the icebox, also the design of the a2w setup, its always very interesting to see what everyone else did as far as the pump use, line sizes, location of tank mounting/ic mounting etc.
Old Oct 5, 2010 | 05:08 PM
ej1 rep's Avatar
Why is the valve cover like that? Looks cool.
Old Oct 5, 2010 | 05:33 PM
seerx's Avatar
I cut holes on top of the valve cover so the stock honda baffling can breath into the box I welded onto the valve cover. Hopefully it will seperate the oil and air before the air passes through the hoses.
Old Oct 6, 2010 | 11:17 AM
I.C.C.'s Avatar
That's a great idea. I assumed you just cut out the top of the valve cover in that area... Very ingenuitive...
Old Oct 6, 2010 | 01:29 PM
B16A2MINI's Avatar
Great Fab work there dude,
Old Oct 7, 2010 | 05:05 AM
Charlie Moua's Avatar
What makes that design better than stock valve cover with the same fittings welded on with a small baffel plate also welded onto the inside of the stock valve cover?
My point is that, it seems like there should be an easier way
Old Oct 7, 2010 | 08:22 AM
seerx's Avatar
You are correct. You could just weld the lines above the stock baffeling and it would be easier. I am trying something different and I hope that no oil will come out of the two lines. If I can get it to do that I will be making another vc similar to this but larger. I will just have the scotch bright pads on top of the vc and the vc and catch can will be one unit. keeps everything compact and nice.
Old Oct 7, 2010 | 06:10 PM
Blown90hatcH's Avatar
Nice work man!
715_guy
Mar 30, 2012 01:11 PM
20ls01
Aug 27, 2007 04:25 PM
k-series
Jun 12, 2007 11:17 AM
k-series
Mar 5, 2007 01:18 PM
joshuma
Jan 30, 2007 05:56 AM
