Piston question for a D15b2
Old Oct 2, 2010 | 06:34 PM
theorigkav3's Avatar
Icon2 Piston question for a D15b2
i have a mini-me swap, and i read in a forum that they said, if i want more power, to put pistons from an D16 in my d15...
If i was wanting to put pistons from a D16A1 Integra, would i have to bore out my engine? or is that engine a 1.5 also?
and, what all would i have to do to replace them?
i dont know much about the bottom end. just the top.
any kind of advice, or help is very appreciative
Old Oct 2, 2010 | 07:54 PM
singlecamsaint's Avatar
Default Re: Piston question for a D15b2
well you would defintly have to bore the cylinders, but i think the problem with this lies within the wrist pin they may or may not be different sizes, i can only speculate this but i do know the main and rod journals are different between the 1.5s and 1.6s, and the d16 in the first gen teggy is 1.6
Old Oct 2, 2010 | 08:02 PM
James_Starks's Avatar
You would need custom length rods and they would fit other wise you will have low compression. bore is same stroke is different
i found two places for the correct pistons
bisimoto and aries
bisimoto is a sponser on here give them a call
Old Oct 2, 2010 | 08:06 PM
prelude182's Avatar
you wont have to bore out the block. you will have to use the same rods in your d15. yes this will make pretty high compression when using a vtec head.
Old Oct 2, 2010 | 08:18 PM
wait so theres no block boring involved, i thought you would but i guess not, but wouldnt kinda cause valve clearance issues
Old Oct 2, 2010 | 10:20 PM
prelude182's Avatar
depends on your headgasket i suppose. unless you upgraded your valves. With my build im using pg7 pistons with a b2 block and not one d-series guru has said it wouldnt work. so im assuming you wont have clearance issues with the valves.
Old Oct 4, 2010 | 07:07 AM
Im tryin to get my hands on some pistons, so ill let you all know how it went.
THANKS GUYS!
ElswickB22
Aug 6, 2013 08:44 PM
92CHB
Oct 10, 2011 07:36 AM
mechmeck
Nov 20, 2003 05:58 AM
