FS/FT: Lots of Honda parts.
May trade some of the following parts for turbo kit parts (turbo sized for stockish B18C, AC compliant manifold) OEM 96-98 clear fogs, 96-98 SiR front lip, decent suspension (shocks/springs, already have sways and ASR), or ???
1. JRSC for GSR head. Comes with everything but maybe a couple gaskets and bolts. You'll also need a new belt. $1200
2. EM1 front sway bar, lower control arms, and lower shock forks. May not have the bolts for the shock forks (they are longer bolts for other Civics). $200 for all.
3. Ported GSR head. Head would be suitable for higher HP all motor or a turbo application. Will sell bare, with Ferrea stainless valves, with stock valves, however you want it. Also have a matching ported GSR intake with IAB's removed (can be put back in if you have them). $800 for head with Ferrea valves, 650 for head with stock valves. Add $75 if you want the ported intake. Will sell intake for $125 separately. NO VALVE SPRINGS included unless you just want stockers.
4. Brand new in box Skunk2 Pro1 cams for B series VTEC. $550
5. Brand new in box Skunk2 Pro series cam gears (titanium color) $225
6. Brand new but no box Skunk2 titanium retainers $150
7. EM1 B16 head with 47,000 miles. Complete head with intake, cams, valves/springs/retainers, cam gears, etc. $600 for all (no dizzy but I do have a VC that would need refinished that can come with it)
8. Stock GSR head and intake manifold. $500
9. Stock GSR head. $400
10. Brand new in box RS Machines 84.5 mm ITR replica pistons for B20. $250, come with rings.
11. Used Eagle H beam rods (small bolt) for B18A/B or B20 (or your GSR with LS crank...). $225
12. Block and crank to go with 10 and 11. B20Zx block bored and final honed to 84.5 mm, micropolished crank. Everything fresh from machine shop and ready to go. $400
13. New OEM honda oil pump (think I have 2). $100 each
14. Set of Crower billet rods. Can't remember if they are GSR or LS/B20 but I will double check the length of them and post back. Fresh from machine shop and ready to go (had checked out and cleaned up; not out of a failed engine). $350
15. EM1 CD player with Honda card with unlock code. Volume control responds slowly. Very good shape cosmetically. $100
16. Set of HX wheels that I started to strip. Tires are OEM HX size and they have around 90% tread remaining. Car always aligned perfectly so NO abnormal wear of any type. On a fuel economy car so no burnouts ever. $350 or trade for ??? wheels (You or I add cash but I do not want anything larger than a 16)
17. Pretty large Ebay FMIC. New but has dings from being fitted and moved around a shop. No leaks. $60
18. P7J AC bracket. Use to retain you D series AC system when doing a B swap on your 92-2000 Civic. With torque mount stud and idler assembly. $90
I will add more parts in the next day or two (once I get over to my shop to inventory more stuff). Also interested in trading or trade plus cash for a clean 96-00 Civic 4 door shell. Not interested in anything rusty, color changed, or with poor body work or paint. Will provide pics of any part(s) listed above once a deal has been stricken. Not interested in providing pics to tire kickers.
Ryan
Ryan
PM's replied. May also trade everything to build the B20 (block/crank/rods/pistons/head of your choice/Pro1's, etc) for a good running ITR swap.
More things I may be interested in trade:
Clean ITR swap
Clean GSR swap
Clean ITR or GSR engine only
Good B series header (RMF Narrow rep, HyTech Tri Y rep, etc. MUST be AC compliant)
QUIET cat back for 96-00 Civic (2.25 or 2.5" and mandrel bent)
SSR Comp/Type C wheels in 15 or 16 (silver or grey center with machined lip)
Good coilovers that ride well for a DD
HID converted OEM headlight housings (OEM projectors installed into 96-98 housings)
Clean ITR swap
Clean GSR swap
Parts I currently would like to have:
Good quality coil over setup or good spring/shock setup that is a mild drop.
SiR front lip for 96-98
Turbo parts for B series
Good running GSR or ITR engine
Complete good running OBD2A LS swap
Low mile HX or VX complete swap
Stock EM1 or CTR air box/intake arm setup
Civic Si cluster
OEM clear round fogs for 96-98 Civic (may consider OEM clear square fogs)
Higher end car audio
Large home theater powered sub (higher end, not box store trash)
Nicer wheels in 15's or 16's
Brake upgrade for 91 CRX (front)
Nice and quiet cat back for 91 CRX (prefer one with dual outlet muffler that looks fairly stock, like Si had)
Need a LOT of CRX interior parts
CRX tall side moldings
CRX front pieces for lower cladding (that go on bottoms of front fenders)
May consider other things in trade, too.
Civic Si cluster
Not sure on the CRX seats yet. Supposed to finalize the deal today to get the car back. PM me what I have that you want and maybe we can work something out.
I'm talking about the piece that attaches to the bottom of the front shock. Goes from shock to lower control arm. On the EM1, that fork is wider at the bottom than all others. I have the correct shock forks to use with the EM1 lower control arms.
WickidSi
Mar 2, 2003 09:42 AM
