Headlight removal 90-93
Old Oct 2, 2010 | 02:01 PM
Backk InTheDA's Avatar
I hate everything
Default Headlight removal 90-93
Don't worry, I searched but the link is broken or something. Or the fitlers are blocking out another websites name. Either way, how do I remove the headlights from my 1990 Accord?
Pictures would be great.
Thanks,
Old Oct 2, 2010 | 03:59 PM
redbull-1's Avatar
Default Re: Headlight removal 90-93
http://www.youtube.com/watch?v=imFikJ78sX4
Old Oct 4, 2010 | 05:14 PM
fleetw00d's Avatar
He is making it a lot harder than it is. Do not remove the bumper skin from the beam; the bumper can be removed easily as an assembly. What he didn't show you is that there are plastic retainers across the entire top of the bumper skin (not just between the headlights, but under them as well) that would need to be removed or cut to get the skin off. You can access the bumper beam bracket bolts by removing the turn signals then using a long estension. Remove the nut on the inside of the engine compartment on both sides (like he showed in front of the battery). With those six fasteners and the plastic grommets on the underside removed, the whole bumper assembly (skin, beam, brackets together) can be pulled forward off the vehicle.
clowery89
May 16, 2010 06:12 PM
johnnyboy31989
Feb 25, 2008 04:34 AM
racerxfactor
Mar 12, 2007 05:08 AM
97LXAcc0rd
Jul 28, 2005 09:20 PM
StreetGlwLude
Sep 20, 2004 04:49 PM
