car jerks, clutch seems unbalanced
Old Oct 2, 2010 | 05:31 AM
Vampire2o9's Avatar
Default car jerks, clutch seems unbalanced
Hi, I seem to have this problem when going from a stop, driving in first gear and a little after shifting to 2nd gear. It seems like I'm not giving it enough gas and it jerks as if I can't drive properly. I am a very good driver in my opinion and this is making me look like a total nub lol.
I was thinking it was clutch cable being too tight, so I loosened it and it felt a little better, but I would still have to either rev it high or slowly drive on 1st to not make it jerk.
Also, my axle seems pretty bad, the housing is off but no tears or leaks. At first I thought it was the axle, like it wasn't fully spinning or something.
The feeling of it is like when you have bad mounts.
My friend has told me it might be the flywheel, how it's not grabbing as good anymore since the clutch cable was tighten and could have worn down the flywheel.
Any thoughts on this matter?
Last edited by Vampire2o9; Oct 2, 2010 at 05:42 AM. Reason: 90 integra jdm LS / b16 cable trans
Old Oct 2, 2010 | 09:45 AM
joss731's Avatar
Default Re: car jerks, clutch seems unbalanced
I would double check all the parts u suspect and posted above. Check all 4 mounts, I kno mine are shot and I'm getting something similar to what ur getting when shifting from 1st to 2nd..g/l
Old Oct 2, 2010 | 09:49 AM
joss731's Avatar
As a matter fact, it culd be more than just one of the parts on ur car. I kno axles may look good from the outside but could have a sheard shaft or worn out cv join. Hope this helps
Old Oct 2, 2010 | 09:56 AM
Drive 4 fun's Avatar
Fix the obvious, axle, but sounds like mounts to me. Does the clutch hold well on a mild hill, or slip and grab?
Old Oct 2, 2010 | 12:54 PM
Vampire2o9's Avatar
Mounts are good and holding, it just feels like it has bad mounts or missing screws but I just checked and nothing could be found to say it was mounts.
On the hill, it's the same, really hard to start off in first. I would have to give it more gas. Now when I think about it, when i press the clutch and slowly try to release it, it does feel like it's slipping as where you would get that term. Like oil was on the tires lol
Once I get back I hope to replace the axle and update you guys.
Old Oct 2, 2010 | 01:42 PM
Years ago I had a clutch/pressure plate problem in a VW. The sensation was almost a shudder or chatter when letting out the clutch, and it was intermittent. The dealer could not find it and would not honor the warranty. Finally, the owner took it home for the weekind and it did it to him in his uphill drive. Fixed. Unfortunately, no free look to find it. It was a different feeling than bad mounts.
I could take the more humorous approach and say if you cannot find the jerk in your car, look in the mirror.
Old Oct 2, 2010 | 02:17 PM
Vampire2o9's Avatar
But honestly i wasn't jerking it in the car!! That's just leftover cream cheese!
Old Oct 2, 2010 | 02:38 PM
Mavi87's Avatar
On accident i discovered that a bad/dirty idle air control valve causes this feeling too. its the sensor behind the intake manifold/ in frot of the firewall. Very far fetched but IT DID happen to me. But the jerking was really bad kinda like when you hit the gas hard then let it go then hit it hard again.
Old Oct 2, 2010 | 07:36 PM
Vampire2o9's Avatar
I will check that out for sure, it does have a problem with the idle being low, but I took it to a shop and they adjusted the timing and throttle screw now it gets pretty high sometimes like 1500 rpm, sometimes normal.
Old Oct 3, 2010 | 12:19 AM
dntnedvtec's Avatar
Seems like a 6 puck to me
Old Oct 3, 2010 | 04:45 AM
Vampire2o9's Avatar
It's an oem clutch. I guess you might be thinking I can't drive or something but this annoyance of the clutch is getting worse over time.
I have to give it more gas then usual, when I try to even it out and slowly release the clutch, still feathering quite a bit, it starts dying out as if I didn't give it enough gas or depressing the clutch pedal to make it stable but I do. Seems like it is not grabbing constantly.
Old Oct 4, 2010 | 06:36 PM
Vampire2o9's Avatar
Clutch cable was messed up causing it to give me more clutch then usual, Had to fully disengage the clutch to let it start moving. Replaced and adjusted now it's fine.
But, Now I stall after I drive on the freeway.. the car just suddenly stalls and I have to restart my car..
Old Oct 4, 2010 | 06:52 PM
aquito's Avatar
i have the same problem..and it just starter a week ago as soon as i installed coilovers on my da9
Old Oct 7, 2010 | 08:22 PM
Vampire2o9's Avatar
fixed all the above, drove it for a few days fine, then started again. Friends telling me it's the master cylinder.. what do you guys think?
Old Oct 7, 2010 | 08:47 PM
red96turbols's Avatar
was this you? Tosh.0 Lexus Pre-own test drive
Old Oct 9, 2010 | 12:39 PM
Vampire2o9's Avatar
Please don't PM me for uncensored versions
Old Oct 13, 2010 | 12:30 AM
Vampire2o9's Avatar
What the hell lol even my mechanics didn't catch this but my ECU finally threw a code.. number 7 and I been checking around and it seems my throttle body or TPS is bad making it idle weird, stalling out, and jerking while getting on the gas after shifting... very very weird but I think this might be the jerking problem.
I would say to try to adjust the throttle screw a little more open but sometimes my idle goes pretty high as well as pretty low.
Think it's the TPS or throttle?
Old Oct 13, 2010 | 01:59 AM
ChR1sCRX's Avatar
I was thinking it sounded like it was missing. If you fan the clutch in and keep the revs high does it go away? If yes, then the car is missing, weather it's an electrical miss or one caused by fuel/tps is anyone's guess.
Old Oct 13, 2010 | 09:57 AM
bank2me's Avatar
I am having the same problem. I was thinking it was a motor mount issue but
I intalled Energy Suspension inserts in the motor mounts and it still kicks when I let the clutch out. I have replaced the clutch and flywheel. I was told to check the lower control arm bushings. I have yet to check them though.
Old Oct 13, 2010 | 01:27 PM
Vampire2o9's Avatar
Even when it's throwing an ecu code 7?
Old Oct 13, 2010 | 01:32 PM
Vampire2o9's Avatar
My friend had the same issue, after a while of wild driving he cracked his frame by the bolts attaching the strut bar where the front shocks/springs bolt into. After you put in the inserts does the car vibrate a lot?
Old Oct 13, 2010 | 02:34 PM
hbcrazy88's Avatar
96 integra ls... have kinda the same prob. when i take off in first its like its wheel hopping like crazy! i was thinking maybe the clutch has hot spots or i dont know.... mine will idle really low as well around like 400rpm, but has never staled on me.
Old Oct 13, 2010 | 06:53 PM
Vampire2o9's Avatar
Mine would stall after I get off the highway. In town, it doesn't stall at all. Today I adjusted the screw a little bit more open and I'm not stalling but idle surges around 400-1000 rpm.
Going to be on the road tomorrow so I will see how that goes. Some of this fixing will have to be on hold for a day or two.
Old Oct 13, 2010 | 07:31 PM
hbcrazy88's Avatar
so i got in my car after work..... and now my heat doesnt work! FTML winter is around the corner. any info on the clutch problem yet? im sure someone has had this in the past and knows what it is!!!
Old Oct 18, 2010 | 09:53 AM
bank2me's Avatar
Damn. Yea it vibrates more with the inserts. It kind of sucks. I prolly wouldn't buy another set. They are in my daily driver Integra so I'm not too big on the vibration.
itslogz
Mar 19, 2008 02:24 PM
jwbnavy
13
Dec 16, 2007 10:52 AM
srv3fender
Mar 24, 2005 07:16 AM
srv3fender
10
Mar 24, 2005 05:28 AM
1.8
23
Jan 16, 2005 02:15 PM
