Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Another Brake Issue Damn the luck
Old Oct 1, 2010 | 02:51 PM
vbspec's Avatar
Default Another Brake Issue Damn the luck
Hey gang.... Well as most everyone has been following Spencers brake issue i now have a problem too. At the last race i notices similar symptoms to what Spence has described... a loooooong pedal. The rotors and calipers were new so i figured it was the master... I installed a new Honda ITR master and bleed using the gravity and pump and release methods. And the pedel felt great. Well Tuesday night I was getting ready to load the car on the trailer to take it to the dyno and with the engine running its pedal to the floor. WTH.... We rebleed all 4 corners with no change. So i figure it may be the booster check valve, and we swap in the one from my dads CRX. No change. Then I started the car with the vacuum hose from the IM disconnected and i have a full pedal. Reconnect the vacuum line pedal goes to the floor. So today i installed a new booster and its better but still feels iffy at best. I also noticed that with the engine running if i pump the braked the rpms fluxuate like i have a vacuum leak. So the best i can figure is to get new vacuum hoses and clamps, and even a new check valve and give it a shot. But could there be something else making the rpms fluxuate?
Any insight would be greatly appreciated..
Michael
Old Oct 1, 2010 | 05:04 PM
Drive 4 fun's Avatar
Default Re: Another Brake Issue Damn the luck
You sound like you know what you are doing and that makes it less likely that someone is going to have a magic answer that you did not already think of. How about MC seal to booster?
Old Oct 2, 2010 | 11:08 AM
vbspec's Avatar
changed hoses and clamps with no change. could really use and idea or two gang.
thanx
braass91
18
Jul 19, 2012 11:38 AM
STN_Pat
Mar 20, 2009 10:55 AM
G0crxG0
Feb 27, 2008 09:33 AM
jikespingleton
Jan 2, 2007 01:31 AM
abeaujuin
May 2, 2005 01:31 PM
