Test Harness
Old Oct 1, 2010 | 02:06 PM
raffaelli's Avatar
Default Test Harness
I am interested in getting a ECU test harness. Anyone have one? Did you built it or buy it?
Old Oct 1, 2010 | 02:17 PM
dem0nk1d's Avatar
Default Re: Test Harness
What the hell is a test harness? Do you mean a conversion harness to convert from obd0 to obd1?
rywire.com
or even ebay...
Old Oct 1, 2010 | 02:28 PM
crx_si-r's Avatar
A test harness is similar to an ecu Conversion harness. Main difference is there are an extra set of plugs that allow you to attach an ohm/voltage tester while the ecu is plugged in and running. If u look in the honda shop manual you an see them being used.
OP, I would just build your own.
Old Oct 1, 2010 | 02:34 PM
dem0nk1d's Avatar
so it's more or less like probes? so a quick and dirty way to do it would use some scotch locks, and run wires off of that with some bullet connectors. This way you can probe away or plug in items if needed.
http://www.hondaworld.ru/manuals/civic95-97_22-2.htm
Old Oct 1, 2010 | 02:36 PM
raffaelli's Avatar
That is what I figured. Thanks.
Old Oct 6, 2010 | 07:46 PM
Josephsride88's Avatar
Hey...I would love to know how to make a test harness...can anyone help me to understand how I might go about building one?
Old Oct 6, 2010 | 09:02 PM
crx_si-r's Avatar
picture says it all
holmesnmanny
Dec 18, 2011 12:51 PM
classicalgq
Jul 31, 2008 11:01 AM
ayavner
May 28, 2008 07:20 PM
Dingo68
Mar 25, 2007 05:32 PM
_Endless_
Aug 28, 2002 06:10 PM
