b16a oil leaking thru gasket
sup h-t
i just finished building a fully build b16a idk if i did something wrong but the motor cranks and it runs but after a while the motor has been running it starts leaking oil thru the head gasket little by little idk if i tight the bolts to much that i squeezed the gasket to much but it blowings white smoke thru the exhaust like if the gasket was blown all the seals are new so its not a cam seal or vtec seal a little help would be nice.....
here are a couple of mods the motor has done
block
balanced crank
type r oil pump
eagle rods
wiseco high compression pistons 12:5:1
sleeved
head
port and polished
omni valves
omni retainers
omni spring set
arp head stuts
cosmetic high compression head gasket
three angle valve job
buddy club cam gears
buddy club cam stage3
blox manifold
rc 310 cc
golden eagle fuel rail
and more i cant remember
but i would like your guys opinion before i tare the motor apart
here are a couple of pics of the swap i need this thing running
thanks!
block
balanced crank
type r oil pump
eagle rods
sleeved
head
port and polished
omni valves
omni retainers
omni spring set
arp head stuts
blox manifold
rc 310 cc
thanks!
ej6sedan b16
15
Jul 16, 2012 02:04 AM
