Suspension & Brakes Theory, alignment, spring rates....
best sway bars
Old Oct 1, 2010 | 06:01 AM
boxeocampeon's Avatar
Default best sway bars
close
Old Oct 1, 2010 | 10:59 AM
98civdx's Avatar
Master Detailer
Default Re: best sway bars
What kind of car do you have?
Are you talking about the 99-00 si? sway bar is 26mm and they run their own lca's and shock forks.
Old Oct 1, 2010 | 06:16 PM
98civdx's Avatar
Master Detailer
From what I see most people say run your car as stock as possible at first, and then go from there.
You should already have a 22mm up front, so mabe throw a si sway in back or something.
Old Oct 1, 2010 | 07:54 PM
the171's Avatar
Im not familiar with blox suspension. My car is a street car that I use for amateur road racing... I run 550R and 450F spring rates. I recently removed my stock sway bars because they were in the way when doing other work. I then went to the track without putting them back on... And ran a best personal time, go figure. I think at our level, sway bars do little unless you have rather soft suspension. I would focus on brakes, tires and skills at this point.
Old Oct 2, 2010 | 10:02 AM
98civdx's Avatar
Master Detailer
all 96-00 civic ex's came with factory front sway bar.
Noithing in rear.
Old Oct 3, 2010 | 01:25 PM
98civdx's Avatar
Master Detailer
Im sure there is a dfference, how much of a difference I can't answer.
Personaly id start with something smaller, a 99-00 si. Remember the bigger the rear bar the more oversteer you will have.
You will also want to get an asr if you do opt with the ctr rear bar.
murderedrsx
Sep 27, 2011 10:51 PM
bock10
Honda Civic (2006 - 2015)
Jan 11, 2008 04:47 PM
SiRay13
Suspension & Brakes
Jan 22, 2006 07:59 PM
hbgsr504
Jul 28, 2005 11:32 PM
krazyk
Suspension & Brakes
Apr 12, 2005 01:55 PM
