Can D16Y7 crankshaft or any other be used in a D16Z6 block?
Old Oct 1, 2010 | 04:39 AM
hatche1's Avatar
Default Can D16Y7 crankshaft or any other be used in a D16Z6 block?
i have d16z6 with a messed up crankshaft and a d16y7 motor with a spun rod bearing. so what my question is can i use the d16y7 crankshaft or any other crankshaft from any other single in the d16z6 block?
Old Oct 1, 2010 | 09:15 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Can D16Y7 crankshaft or any other be used in a D16Z6 block?
same crank
Old Oct 1, 2010 | 09:41 AM
94EG8's Avatar
Seagull Management
Originally Posted by rick_rabies
same crank
Not exactly true but it will work. The Z6 has two oiling holes per journal, Y7/Y8 cranks only have one.
Old Oct 1, 2010 | 09:52 AM
I'm not Rick!
itl work though
Old Oct 1, 2010 | 05:13 PM
hatche1's Avatar
ok cool thanks for the info guys
Old Apr 21, 2011 | 11:08 PM
hatche1's Avatar
Went with the z6 crank instead
Blackcougar141
Mar 13, 2015 02:42 AM
yz125rider21
Jan 11, 2006 09:39 AM
delslo93
Mar 18, 2005 01:26 PM
junkyard racer
Nov 29, 2004 06:54 AM
KStuned
Sep 4, 2003 02:10 PM
