suspension/brake help
Old Sep 30, 2010 | 07:10 PM
accord1994supra's Avatar
Default suspension/brake help
I have a 94 accord that I need some help on. First time on this forum. I have my accord for 10 years now, 250,XXXmiles and still going. Its been good to me but now just some problems with the brake/suspension. When running over little pot holes, bumps, rough streets, its making some noises, sound like the suspension is loose somewhere. But when I tap the brakes running over the rough streets it doesnt make those noise. I just recent got all four new brake calipers, brake pads, and rotors installed. All new ball joints and tie rods. Ive checked all the suspension and nothing is loose while the car is on jackstands. Before I put all these new parts in.... the car was already having this problem. Now i just need some help on this situation. Thanks in advanced.
Old Oct 1, 2010 | 02:37 PM
poorman212's Avatar
Default Re: suspension/brake help
Your other post stated you've replaced, inspected the swaybar busings/links. I think you said one other busing is bad. If replacing the bad bushing doesn't help (if it is bad it needs to be replaced), then I would inspect the strut mounts.
Old Oct 1, 2010 | 04:46 PM
Thanks, I will replace those bushing to see if the problems goes away.
Mishako129
Jun 10, 2012 10:03 AM
aalb1
16
May 18, 2006 03:39 PM
94maroonturbocp
Oct 23, 2003 03:18 PM
m0dr0cker
Oct 8, 2003 10:34 PM
