i need primer or not?
titi_vtec: you don't need primer, you need sealer. some brands use the same product for both, just at different consistencies (thin for sealer, thick for surfacer). try to find a brand, like PPG, that uses a separate sealer product as it has a better 'bite' or 'etch' characteristic to it. you'll get a longer lasting paint job that way.
for anyone who still has it backwards...
primer has nothing to do with paint work, it's the last step in body work. primer gets applied relatively heavy over bare body work and is then block sanded (like body filler) to give you a perfectly smooth surface to apply the top coat to. sealer on the other hand, is the very first spraying step in paint work. sealer is mainly used to even out the panel's color underneath the basecoat so that you get a consistent color across the entire panel or car. sealers also sometimes have an etching property to them so that they bite into the coating below them on the panel. sealer also does as the name suggests, and 'seals' the surface so that you get no bleeding of colors into the base coat color.
jxhxb
Dec 26, 2007 10:08 PM
