One front brake pad wearing significantly more than the other 3
Old Sep 30, 2010 | 03:58 PM
AndyD's Avatar
Default One front brake pad wearing significantly more than the other 3
Hey guys,
I noticed 3 or my brake pads have plenty of meat left on them but the inner passenger front brake pad is almost dead. What do you think could cause this? The brake pedal feel is not that great. It feels kind of soft, but not toooooo bad. I wish it was firmer.
Any ideas on what it could be?
Old Sep 30, 2010 | 04:06 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: One front brake pad wearing significantly more than the other 3
The brake isn't fully releasing is most likely the cause - causes it to drag across the rotor and wear quickly. I'd start with checking for anything bent - then bleed all your brakes.
Old Sep 30, 2010 | 05:11 PM
AndyD's Avatar
Hmmmm, GREAT suggestion! I noticed a noise coming from my front passenger side of the car when I make a shapr left turn.
I'll give that a try! Thanks!
Old Sep 30, 2010 | 05:25 PM
Also, check to see if the piston is retracting completely - it's possible the grease has dried up on it and it is stuck extended....
c 2
Jan 29, 2008 07:06 PM
stuie08
Dec 13, 2006 03:24 PM
roundworldsobig
Aug 26, 2006 06:12 PM
Ms.JDMdb8
Jul 8, 2005 03:53 PM
Ninja Mike
May 27, 2004 07:20 PM
