B18b longblock, crower cams/springs/retainers, & b16 hydro transmission
Up for sale I have a obd2 b18b motor that has the following installed:
Crower 403 (Stage 2) Camshafts
Dual valvesprings/retainers from Crower
ARP Headstuds
New waterpump/timing belt/tensioner installed with everything
NGK Plug wires
NGK Iridium plugs
New cap/rotor/ignitor(ignition module)
Thermal Intake manifold gasket
Omni power 70mm throttle body
The bad: does burn some oil. Nothing too terrible, I believe it to be the rings.
Looking for $800 firm for the longblock.
Also have a b16 hydro transmission that has no grinds and will have a new main shaft bearing and some new seals replaced prior to sale.
Looking for $600 for the transmission described, or $450 as it sits now.
Will make a deal for someone if they buy the combo.
Hasport mounts are not for sale.
Also clutch/flywheel is not included.
ARP Headstuds
NGK Plug wires
NGK Iridium plugs
What kinda car was it in was it tuned when it was ran did u run it at the track how much for the trans and engine 800 is alot for a longblock ls with mild cams and a 70mm tb
Feel free to make an offer on the combo. I am firm on the longblock.
Also forgot to mention the car has 6 bolt cam gears (forgot the brand) and an str cam plug.
gen2integra2001
Jan 18, 2010 10:12 PM
ph0shizzle
Oct 6, 2006 09:20 PM
