Skunk2 IM idle high
I have a GSR throttle body with new OEM gasket, skunk2 intake manifold with extended studs and Hondata gasket on my B18c1.
Just got it running and she idles around 2200 RPMs.
The only thing I can think of is some sort of vacuum problem.
I am no longer using the charcoal canister or PCV valve.
I am trying to keep my engine bay as simple as possible.
Anyone know what kind of vacuum line diagram to go by or where to find it?
Any suggestions on how to run vacuum lines.
22,000 damn thats high lol j/k how tight is the manifold bolts? and did you plug up the line for your pcv hose? and the rear line that on the back of the manifold?
LOL! I had a leak on my throttle body.
I had a brand new OEM throttle body gasket on my throttle body.
I must have over tightened it because I replaced it today with a Felpro gasket, just snugged it up and problem solved!
sean2000gt
Jul 21, 2010 09:55 PM
type Gendy
50
Aug 31, 2006 09:52 AM
