98 EX: A/C not cold, hissing/vacuum noises
Old Sep 30, 2010 | 07:50 AM
macson's Avatar
Default 98 EX: A/C not cold, hissing/vacuum noises
Hey guys,
Weird thing going on with my A/C lately, was wondering if anyone had some troubleshooting steps or ideas. I've checked the charge which looks perfect, it engages just fine and all, but doesn't blow cold unless it's fairly cool outside already. It has also been making a hissing noise from the glovebox/blower area, sounds like it could be a vacuum leak. I was talking it over briefly with mechanic I know, who says it could be a vacuum-activated valve/door that isn't closing all the way when the A/C is turned on. Anybody have any insight on this, or does this sound familiar at all? It's a 98 EX.
Old Sep 30, 2010 | 12:03 PM
macson's Avatar
Default Re: A/C not cold, hissing/vacuum noises
Bump for the afternoon.
Old Sep 30, 2010 | 12:16 PM
Former User's Avatar
Default Re: 98 EX: A/C not cold, hissing/vacuum noises
Have you checked whether the heater valve on the firewall is stuck partially open?
Does the condenser fan run while the compressor clutch is engaged?
Have you measured the refrigerant pressures on both the high and low sides with the engine idling and the A/C on?
Some refrigerant hissing from the evaporator is not abnormal.
Old Sep 30, 2010 | 12:28 PM
macson's Avatar
Refrigerant pressures are perfect, condenser runs with no problems. Haven't checked the heater valve, where about on the firewall is it?
Old Sep 30, 2010 | 12:45 PM
What are the pressures and under what conditions? The more detailed information you provide, the better chance of pinpointing the problem.
Old Sep 30, 2010 | 01:09 PM
tico's Avatar
umm our vehicles dont have a vacuum controlled doors. lol.... a hissing sound is normal but not common.. i would have the ac system serviced with a 30 minute evac to help relieve and moisture withi in the system.. have it charged and go from there...
Northernlightz
Sep 20, 2016 09:46 AM
JDMCIVIC919
10
Sep 26, 2011 11:37 AM
98sLicKvIc
Jul 5, 2009 05:57 PM
taejin11
Mar 21, 2004 04:20 PM
Kfactor
Nov 5, 2003 11:02 AM
