JRSC from ITR/CTR/B16A head to fit to B18C1/B18C4 - GSR P72 head HELP!!!!!!
Old Sep 30, 2010 | 06:36 AM
HondaImplanted's Avatar
Icon2 JRSC from ITR/CTR/B16A head to fit to B18C1/B18C4 - GSR P72 head HELP!!!!!!
Hi all, just found Jackson Racing supercharger from B16A2 civic with all gear like pulleys and brackets for sweet price!!
I have GSR DC2 integra, motor B18C stamped with P72. I know it doesnt fit just like a bolt on...
Is it possible to work around it just by drilling extra holes in JRSC itake flange to match bolt paterns from my P72 GSR head, or so I have to give it all to machine shop to do all the work like welding IM flange from my GSR IM on to JRSC?
Throw your advices, experiences and ideas please
Old Sep 30, 2010 | 07:01 AM
speedoptions.ca's Avatar
Default Re: JRSC from ITR/CTR/B16A head to fit to B18C1/B18C4 - GSR P72 head HELP!!!!!!
You should weld on the gsr intake manifold flange.
You will run into alot of problems if you just drill it because you will not be able to torque the bolts down evenly. This will most likely cause coolant/vacuum leaks.
Old Sep 30, 2010 | 08:40 AM
be18see1's Avatar
Just buy it and flip it. Then buy a GSR JRSC.
Old Sep 30, 2010 | 12:04 PM
I'll better go turbo road I guess as for that price of SC + machine job and be put at 0.5 bar as for now to run on stock internals... I'd get eGay turbo kit for around the same and it fits just right in then get ecu tuned and can run my the very same 0.5 bar safely w/o modding my IM...
will have to leave it as here's no handy machine shop around so...
Old Sep 30, 2010 | 12:13 PM
1998GsRIntegra's Avatar
Find a b16 head on the cheap? Just a though. I have personally found ebay "Generic Brand" parts to be unreliable and cheaply made.
Old Sep 30, 2010 | 02:10 PM
AcuraIntegraLS-T's Avatar
If yo search you will find out that you can drill the jrsc b16 manifold to fit the gsr head, the manifolds are made from the same cast. It has been done before.
Old Sep 30, 2010 | 05:51 PM
seriously? I have like 15 hours to let my man know weather I will take it from him or not... Im dead busy and I would be more than delighted and thankfull if you could provide me with some information about it... thanks
Old Sep 30, 2010 | 06:39 PM
This might help you out. The pics are gone cuz its so old but it still gets the general idea across. https://honda-tech.com/forums/road-racing-autocross-time-attack-19/itr-intake-manifold-gsr-head-1567814/
Old Oct 1, 2010 | 12:31 AM
thanks alot man
Old Oct 1, 2010 | 10:16 AM
Originally Posted by 1998GsRIntegra
This might help you out. The pics are gone cuz its so old but it still gets the general idea across. https://honda-tech.com/forums/showthread.php?t=1567814
If you read the post he makes, there is a hole where the coolant goes. Unless you weld closed the unused hole in your manifold, in the long term you may run into coolant leaks.
Or you could do what he did in the last post he made, tap the hole and seal it with a plug.
Originally Posted by GSRCRXsi
just figured id update this.
the gasket wasnt sufficient enough to seal against the coolant port. so it leaked. im 99% sure it was because there wasnt anything backing it. so i tapped the port on the head to 1/2" npt and plugged it. all sealed up now
Old Oct 2, 2010 | 07:52 AM
Ok, bought the JRSC kit for 770eur ... will be rebuilding it (at least its gaskets) in short future and will be either looking for cheap full CTR head with all its contents in good condition, or either just going to look for GSR IM and will have to find workshop thats going to do me all the job...
Do yous think its a good price I've payed?
Old Oct 22, 2010 | 03:35 AM
ok, here's the plan, will be drilling holes in in after all anyway
jdmintegra18
Mar 16, 2009 08:17 PM
91glassycrx
Nov 24, 2004 03:27 PM
jabroni95gsr
Jun 4, 2002 11:03 AM
vietgsrboi
Mar 28, 2002 08:49 PM
