ECU plug pin parts numbers?
Does anyone know the AMP part numbers for the ECU plugs on an OBD I setup?
I need to add the female pin into the plug for the VTEC solenoid, which my harness does not currently have. When looking into it, I saw that there are two different sizes in plug A, the VTEC one is the larger one.
Thanks
Thanks
i presume you're talking 88-91 crx and civic. With those I always stick a 18 guage wire in there and works perfectly. I think there is also an unused "big" pin that you can take out and use in place but cant remeber which
Greg
Greg
Well it is a CRX, but I am putting an OBD I adapter together to run the AEM EMS. The plugs I have from a 92 Civic don't have the VTEC pin, which is what I am looking for.
I hear what your saying on the A plug for a Pre-OBD car where it is big enough to insert a wire in there.
shbrown
Aug 11, 2005 04:51 PM
kinvid22
Nov 8, 2003 10:18 AM
JDM CRX
Mar 25, 2002 08:01 AM
