BWR Rear Subframe and OEM rear sway.
I have a 98 GSR and recently purchased a BWR rear subframe brace. I am having trouble with the OEM rear sway working with the brace, almost like the holes for the sway were drilled incorrectly or something. Anyone else by chance have this issue? Or if you have successfully used this combo, please chime in or even better yet... post some pics. Thanks.
it might just be it is made a for a larger bar with different d brackets. Someone had this issue with asr and they different d brackets and opend up the hole a little bit.
does what I said make sence?
spaazm
Apr 13, 2014 10:17 PM
