vtec not working
Old Sep 19, 2002 | 10:07 AM
tunes12's Avatar
Default vtec not working
so i've finished a swap of a b16 into a 91 crx si and everything went fine. I've even taken care of the code 6 and 7 check engine lights. for some reason though, the vtec still does not kick in. I have enough oil, my speedo works, I waited until it was up to tempurature and it still does not work, even without any check engine lights. anyone have any ideas? Any help would be great.
Old Sep 19, 2002 | 11:39 AM
Shea-bird's Avatar
New User
Default Re: vtec not working (tunes12)
is your solenoid clean? I am going through this now also
Old Sep 19, 2002 | 12:13 PM
Jeff C's Avatar
what ecu?
Old Sep 19, 2002 | 04:40 PM
Mikey's Avatar
Default Re: vtec not working (Jeff C)
1) Oil level, its gotta be FULL. I'm talking at the upper mark on the dipstick.
2) Solenoid, Ok this is a 2 parter. A) take a wire (any wire) disconnect the grey plug on the vtec solenoid and touch the wire to the pos. battery terminal and the solenoid side of the grey 1 pin connector. there should be an audible click from the solenoid. B) If A checks out, remove the solenoid and clean the filter screen. (self explanatory)
3) Speed, the car must be going over 10 mph so the speedo must be working. that means the VSS has to be working. vtec is temperamental isn't it?
4) more oil, check the oil pan. if its dented POUND IT OUT!.
5) ECU Swap out to another ECU that you KNOW vtec works on.
6) Car must be at I belive its 80 degrees or higher so let car get to a normal operating temprature.
7) If none of the above work, you might want to pull the solenoid off the head, remove the solenoid filter and verify the piston moves freely.
see original post: https://honda-tech.com/zerothread?id=164863
[Modified by Mikey, 1:41 AM 9/20/2002]
[Modified by Mikey, 3:27 AM 9/21/2002]
Old Sep 19, 2002 | 05:31 PM
tinkerbell's Avatar
Default Re: vtec not working (Mikey)
YO!!!!!!!!!
Mikey - always acknowledge your source or you will be flamed HARD on this one!
HERE it is:
thanks KAMiN!
t..
Old Sep 20, 2002 | 05:06 PM
tunes12's Avatar
I have a pr3 ecu.
Old Sep 20, 2002 | 06:31 PM
Mikey's Avatar
I'm sorry KAMIN. I wasn't trying to act like I knew everything. I've so many posts with this question so I saved the original reply on my HD.
SORRY!!! my post has been edited
[Modified by Mikey, 3:32 AM 9/21/2002]
Old Sep 25, 2002 | 05:04 PM
Vtec92Civic's Avatar
I got a D16z6 SOHC VTEC in my 92 Civic EX, and my VTEC is not working either. My friend's VTEC is real loud in his Civic EX, and his car is fully stock. I got an AEM Cold Air Intake, and was told I should be able to hear the VTEC better with an intake, but I don't hear or feel any difference. Can someone please help me out? E-mail me at: crazeone69@aol.com I just actually found out that I had VTEC a few days ago, but I just want it to work.
Thanks Everyone,
Tyson
p.s. e-mail me or post here.
Old Oct 2, 2002 | 06:31 PM
Kamin's Avatar
no worries
as long as the info gets out there and you dont say "i wrote this he is lying"
i dont give a ****
im sure its helped people so its done its job
Kamin
Feb 11, 2012 07:53 AM
EF_LSVtec
May 31, 2003 08:05 PM
jg
Jun 25, 2002 06:57 PM
Chuji
May 12, 2002 10:42 AM
B16CRXhybrid
Apr 18, 2002 06:48 PM
