ek with gsr swap misfiring
no cel codes
changed plugs
still sputters
i have magnecores leads
gunna switch back to oem leads see if it fixes it
i change the cap and rotor arm when i did the swap
changed plugs
still sputters
When you have a misfire problem, always start by focusing on the ignition system.
Does the CEL work? Have you inspected the cap and rotor? When was the fuel filter last replaced? Have you tested the coil?
kulo
Aug 4, 2010 11:31 AM
