F22b SOHC Vtec engine timing
HI all,
can anyone provide me a engine timing pics, how to align balancers, cams, crank etc when installing timing belt?
Appreciate quick replies here
Here you go budd! This is for the Timing Belt.
Your cam gear should line up like this as shown here:
Then this little crankshaft gear is located behind the big crank pulley, so make sure you have it timed as shown here in this picture. You can see the arrow on the oil pump housing to lined up with the dimple on the gear tooth :
Then when you have the crank pulley on, make sure everything else is aligned as shown here:
For balancer shaft alignment, look in the FAQ section.
Heres the Link For Chilton
http://www.chiltonlibrary.com/Index.aspx
and as already mentioned, check the FAQ sticky. There is a complete write-up with pictures and instruction on how to properly set the timing and balancer belts.
