Looking for this particular flex pipe
Old Sep 29, 2010 | 06:38 AM
90blackcrx's Avatar
Default Looking for this particular flex pipe
I'm looking for a smaller flex pipe for dump tubes, but they don't have the normal look that you're use to seeing, it almost looks like a piece of pipe, fattened up a little bit and then crinkled.
Almost like this, but not really, quickly google searched this
Old Sep 29, 2010 | 06:44 AM
kyden's Avatar
Default Re: Looking for this particular flex pipe
this stuff? i see it at autozone all the time
Old Sep 29, 2010 | 06:45 AM
9bells's Avatar
OG Fabricator
Reid Washbon
Old Sep 29, 2010 | 07:00 AM
90blackcrx's Avatar
No, not that stuff. Its flex pipe, but it just doesn't have the strands of metal you're use to seeing.
9bells this is pretty much it
http://www.reidwashbonracing.com/rac...s/bellows.aspx
Any ideas on how much they go for ?
Old Sep 29, 2010 | 11:16 AM
k24em2's Avatar
spdexhaust sells those, the 2" is 183.00
Old Sep 29, 2010 | 11:56 AM
CRMB's Avatar
OG Fabricator
Pop the end caps off a regular flex section with a screw driver. Then you can remove the cosmetic outer & inner lining. You will then have just the hydroformed ribbed tubing that will look like that.
Old Sep 30, 2010 | 09:41 AM
hootiehoo's Avatar
http://www.034motorsport.com/fabrica...and-p-625.html
less than 40$
Old Oct 1, 2010 | 07:36 AM
90blackcrx's Avatar
Originally Posted by hootiehoo
Thanks man.
non-VTEC
Welding / Fabrication
19
Apr 23, 2012 12:17 AM
1QwIkEf
Dec 20, 2011 04:31 AM
PolishSasquatch
Apr 8, 2008 02:57 PM
r0yal
Apr 19, 2006 07:03 PM
FURACERMAN
Jan 6, 2006 06:32 PM
