Honda CR-V & Element 2WD & 4WD Element & CR-V
2002 CRV (K24) IACV location?
Old Sep 28, 2010 | 09:30 PM
sol_searchin's Avatar
Default 2002 CRV (K24) IACV location?
Anyone know where this is? easy to take off and clean??
blow out's from honda would be GREAT! thanks
Old Sep 28, 2010 | 10:35 PM
lazlong's Avatar
Default Re: 2002 CRV (K24) IACV location?
It's on the throttle body #1: http://www.bkhondaparts.com/billkay/...itch=&hidIrno=
Old Nov 3, 2014 | 01:25 AM
luweedee's Avatar
I do also have a 03crv ivtec with a irritable idle. I have sprayed all the ports in the throttle valve to no effect.
Old Nov 5, 2014 | 04:56 AM
Syper's Avatar
It might be the gasket that's on there than! There's like an O ring on there. BE VERY CAREFUL WITH IT!!! YOU CANNOT BUY IT FROM HONDA!!! Honda will try to sell you the entire throttle body
I had the same problem on our other 03 CRV. I took it off sprayed it, then sprayed it again. Gave up and bought a new one. Took off the old one and then noticed that the O ring wasn't sealing correctly when you screw it back up.
New one worked like a charm! The CRV was stalling and crazy idle before I replace it with a new one.
rpfn140378
Dec 22, 2013 05:58 AM
got00rice
Feb 5, 2010 11:32 PM
civperc
24
Feb 12, 2004 06:17 PM
lilbill3554
Jan 28, 2004 07:39 PM
