LSVTEC Dyno 82mm
Old Sep 28, 2010 | 08:09 PM
MrMike's Avatar
Default LSVTEC Dyno 82mm
Finally got the build tuned. This is my daily driver. I built it to be on the conservative side so i can still run 87 octane and get good gas mileage while driving pretty chill. I get over 40-45mpg with this setup and all i have to do is swap in the larger injectors, hondata, good gas and have the power you see below.
B18b1 82mm x 89mm
P72 GSR 82mm pistons
Stock rods w/ ARP rod bolts
ARP head studs
P72 GSR head ported and polished
Est. Compression 10.5:1
Stock valves, RM Gen II valve springs, Skunk2 titanium retainers
CTR intake and exhaust cams
Skunk2 intake manifold w/ thermal gasket
Omni 68mm throttle body
3” shortram intake w/ velocity stack
DC Sports JDM Header 2.5” collector
2.5” exhaust w/ test pipe
MSD 6A and Blaster coil
OBD II Prelude injectors 290cc
P75 ECU VTEC conversion Hondata S100
http://www.youtube.com/watch?v=Ixf0uDa2EeI
Old Sep 29, 2010 | 12:33 AM
95skunkedgsr's Avatar
Default Re: LSVTEC Dyno 82mm
not bad for what you where shooting for
Old Sep 29, 2010 | 12:39 AM
Sleeper EM1's Avatar
But the Dyno was done on 91+ Oct. correct?
Old Sep 29, 2010 | 01:23 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
thats a neat build. I love MPG
Old Sep 29, 2010 | 06:39 AM
neverstop's Avatar
that's awesome man, what's the trick for >40mpg??!
I barely get 38-40mpg if I coast all the time and drive only on the freeway at annoyingly low speed. I've got an ls vtec with gsr cams and an LS tranny in an eg hatch.
Old Sep 29, 2010 | 08:10 AM
.Manny.'s Avatar
Touching My Member
^^Because I'm jealous! Lol, I get like 18-20mpg from my B20Vtec. Oh well.
Old Sep 29, 2010 | 09:32 AM
DDTECH's Avatar
Thats actually good numbers for a pretty hindered setup..
a better manifold / cams would probbaly break 200whp.
Old Sep 29, 2010 | 12:47 PM
.Manny.'s Avatar
Touching My Member
Not trying to threadjack but, what kind of mpg do you get from your set up?
Old Sep 29, 2010 | 12:48 PM
2k.civic.si's Avatar
better cams and exhaust manifold would definitely increase VE and probably allow him to get a few more mpg's out of it.
Old Sep 29, 2010 | 12:51 PM
DDTECH's Avatar
In a eg hatch back, a full tank , gives me about 380miles give or take how i hit vtec / lay into it..
Old Sep 29, 2010 | 12:54 PM
Loved
Community Favorite
I average about 28-32mpg mixed driving with my 2257cc h2b.
Old Oct 1, 2010 | 04:06 PM
MrMike's Avatar
thanks for the comments guys. Does any one know what the dip right after the vtec switch over at 4500rpms is?
Old Oct 1, 2010 | 06:00 PM
Loved
Community Favorite
what ever it is it doesn't look too bad to me.
Old Oct 3, 2010 | 07:46 PM
MrMike's Avatar
I thought it had some thing to do with the iab tuning because the stock computer had the same dip and the iabs open around 5500rpm on the gsr.
MrMike
Oct 26, 2011 07:35 PM
prettylew
Apr 13, 2008 12:44 AM
DANG YO
23
Mar 26, 2006 09:32 PM
Vtak
Aug 9, 2004 12:31 PM
STHPERFORMANCE
20
Nov 1, 2003 07:09 AM
