engine wiring question - OBD0 engine, OBD1 harness and ECU, and OBD2 car
Old Sep 28, 2010 | 05:50 PM
alsxe10's Avatar
Default engine wiring question - OBD0 engine, OBD1 harness and ECU, and OBD2 car
OBD0 engine, OBD1 harness and ECU and OBD2 car
enough said
advice,
thx in advance
Old Sep 28, 2010 | 06:16 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: engine wiring question
Not enough said:
What OBD0 engine?
What OBD1 harness and ECU?
What OBD2 car?
Old Sep 28, 2010 | 06:18 PM
Hello Bart's Avatar
wow.. i guess we are supposed to guess what your asking too
Old Sep 28, 2010 | 06:22 PM
alsxe10's Avatar
srry guys B16A OBD0 engine, EG OBD1 harness P30 ECU, OBD2 98 EK shell
Old Sep 28, 2010 | 06:27 PM
Technical Hero
Does the 98 have the engine harness? If it does your best bet will be to use that. Add some plugs (VTEC, VTEC pressure switch, knock sensor, extend the fan switch to the back of the block, use an OBD2 distributor, convert the 3 wire IACV to 2 wire, extend the primary O2 sensor to before the cat, swap over the plug for the alternator, use OBD2 injectors from an 96-00 EX civic, use an OBD1/2 exhaust manifold for B16A, change over the plug for the IAT to the round style, convert the ECU plug wiring from OBD2 to OBD1). You've got a lot of work ahead of you. You could also find a 99-00 Si harness and would still have to convert some of those I listed above. Hope you're not in Cali.
Old Sep 28, 2010 | 06:34 PM
Hello Bart's Avatar
dont forget the obd-0 b16 doesnt have the map sensor mounted to the throttle body... you would have to run a vacuum line to a firewall mounted one..
Old Sep 29, 2010 | 02:48 PM
alsxe10's Avatar
Default Re: engine wiring question - OBD0 engine, OBD1 harness and ECU, and OBD2 car
I've got the map sensor, now just waiting for the motor to be pulled from my eg, and the arrival of my EK
Old Sep 29, 2010 | 04:32 PM
Technical Hero
or use one from an OBD1/2 DOHC
Old Sep 29, 2010 | 06:02 PM
alsxe10's Avatar
what can I use from my eg that will also fit the ek? axles, linkage, etc...
Old Sep 29, 2010 | 06:34 PM
Tetanus's Avatar
Yea the axles and shift linkage will work.
Not all of your engine mounts will work. What does work in EKs are: (1) Integra transmission mount & (1) Integra torque mount . You should already have this in your B swapped EG
Use the B16A pedestal mount from your swap and the fluid-filled mount from the EK chassis
You need a 99-00 Civic Si rear engine bracket. You can either source this used on here or new from Honda.
Good luck
Old Sep 29, 2010 | 07:06 PM
alsxe10's Avatar
so I just basically need the rear T mount from a em1?
civicb18c1swap
Engine Management and Tuning
Jun 27, 2010 04:56 PM
screen_name
Apr 22, 2006 06:56 PM
JCracer723
10
Jan 17, 2005 06:24 PM
vshivik
Aug 28, 2002 12:29 PM
