TIMING !
Old Sep 28, 2010 | 02:31 PM
hey man's Avatar
Default TIMING !
hey guys im timing my b series and i ran into a promblem . i put my #1 piston all the way too the top , then i tried too match the lines on the cam gear to the deck . but when i do the cams lift up the cam caps . ( reminder cam caps are not torqued down ) can i just losen the camm gears and line up the lines to the deck height then tighten the cam gears ????? thanks
Old Sep 28, 2010 | 06:49 PM
bambam's Avatar
Default Re: TIMING !
(reminder cam caps need to be torqued down)......Does that help you?
Old Sep 28, 2010 | 06:51 PM
bambam's Avatar
I HOPE this means TDC...
Old Sep 29, 2010 | 05:08 AM
hey man's Avatar
Yea TDC I couldn't think of that lol but when I torque the cams down like I have done I can't spin the cams to line up the lines on the cam gears to the deck . Unless I'm tooo week too lol idk
Old Sep 29, 2010 | 10:11 AM
bambam's Avatar
Are you using assembly lube on the cam gears? Are you torquing down the cam caps/rail bolts to the proper torque and in the proper sequence?
Old Sep 29, 2010 | 10:16 AM
EmminoDaGreat's Avatar
sometimes its hard to get them to stay without the belt, you may need to line it up, put a belt on then line the other and slip the belt on..
mouab18c1
32
Aug 3, 2011 06:00 PM
KURUPTinc
Apr 17, 2008 09:31 PM
skata89
Nov 26, 2006 05:00 AM
turbotime
May 14, 2006 04:06 PM
mtwnfabrication
Aug 10, 2005 12:03 AM
