1993 Civic VX CEL issues (please help)
Old Sep 28, 2010 | 11:00 AM
DirtyCIV's Avatar
Default 1993 Civic VX CEL issues (please help)
i was browsing for a good couple hours to see if anything was posted that could help and unfortunatly i couldnt find anything similiar, so i posted something new..
vx issues..
i need major help with my VX its driving me up the wall, prior to me purchasing it apparently there was a swap im not sure what motor it had in it before but under the hood its the d15z1 motor which i know is correct but on the harness it has plugs that are missing, inside of the car they replaced the dash and cluster with a integra gsr dash (idiots) and all the wiring under that to my ecu is straight GARBAGE. to top it off i have a CEL for code 22 (im gonna check in the morning again to see if its changed) i did replace the pressure switch but still no luck, i did all the actions to reset the light but no luck. its just odd cause the car runs just fine ** so im thinking its a wiring issue, please help thank you so much, - Jason
ps. its running rich too and i think thats a possibility of the cat being bad (any help is always good, thank you!)
Old Sep 28, 2010 | 03:06 PM
jadziasman's Avatar
Default Re: 1993 Civic VX CEL issues (please help)
"inside of the car they replaced the dash and cluster with a integra gsr dash (idiots) and all the wiring under that to my ecu is straight GARBAGE"
You weren't aware of this when you bought it? If not, they were indeed idiots to butcher a VX like that.
But, if you already knew of SOME of these changes before you bought it - GUESS WHAT?
You're probably going to need a service manual to solve this problem.
Last edited by Former User; Sep 28, 2010 at 07:29 PM. Reason: Posting links to service manual downloads is against site rules.
EGvxhatch
Jun 13, 2015 07:33 AM
nemesis25
Mar 17, 2012 04:44 PM
94vxHatch
Aug 28, 2011 09:25 PM
crazy_ls_90
Feb 14, 2009 07:08 PM
navin
Mar 6, 2003 05:56 PM
