built b20v fs
motor
3000 obo for long block
1500 for the bottom end
motor is still in the car so u can hear it run and feel how it drives
-bottom end
b20b4
decked. cleaned. and honed to 84.5mm
crower ultra light rods that are custom length
endyn roller wave pistons 12:5:1 (rated for stock rods before decking the block and resurfacing the head)
crank was micropolished and balanced
new oem water pump
new oem bearing
new piston rings
type r oil pump
stock oil pickup
new main seal.
new oil pan gasket
blueprint b20v head gasket 84.5mm
billet aluminum ud pulley only for alt.
-b16 head (freshly rebuilt)
type r valves
type r springs
type r retainers
type r valves seals
3 angle valve job along with a port and polish
new dizzy with ngk wires
bdl cam gears
toda timing belt
edelbrock performer x intake mani
68mm throttle body
plan on going boost so if u got anything i may do a partial trade
text prefered 262 995 8080
-bottom end
b20b4
new oem water pump
new oem bearing
new piston rings
type r oil pump
stock oil pickup
new main seal.
new oil pan gasket
type r valves
type r springs
type r retainers
type r valves seals
bdl cam gears
toda timing belt
68mm throttle body
proracer718
Jul 28, 2009 11:32 AM
N~FaMouSKhMerBoi
Nov 5, 2002 08:27 PM
