JRSC 11 PSI High Boost Pulley for ITR ?????
Old Sep 28, 2010 | 09:36 AM
ITR 05082's Avatar
Default JRSC 11 PSI High Boost Pulley for ITR ?????
Hello,guys i Need the 11 PSI JRSC High Boost Pulley for ITR,where can to buy this Pulley????Please help.
Thanks
Old Sep 28, 2010 | 10:28 AM
Spawne32's Avatar
Default Re: JRSC 11 PSI High Boost Pulley for ITR ?????
http://www.pulleyboys.com/store/cata...ulley-p-1.html
Old Sep 28, 2010 | 01:11 PM
ITR 05082's Avatar
Thanks
Is 3,4" 4Rib Pulley = 11 PSI on ITR with stock ITR Crank Pulley???????
Old Sep 28, 2010 | 01:18 PM
Spawne32's Avatar
not sure what the calculation is for the ITR to determine the boost level, i just know thats the only place left to buy the pulleys
Old Sep 29, 2010 | 01:06 PM
ITR 05082's Avatar
Nobody knows????
Old Sep 30, 2010 | 05:06 PM
Blown90hatcH's Avatar
Its been a loooooong time since I did the setup, but I think a 3.4" pulley will yield what you are looking for. Contact the John at LHT performance in Clearwater FL and he will be able to help you. He was one of the first ever guys to go up in the boost on those things.
http://www.lhtperformance.net/
Old Oct 5, 2010 | 10:15 AM
ITR 05082's Avatar
Thank you very much
Old Oct 7, 2010 | 04:41 PM
Ldo's Avatar
Ldo
Using 3.8 nose pulley, a stepper pulley at the alternator, and a CRV crank pulley should get you over 11psi. Belt slippage and heat will be a major issue. You can buy the 3.8 pulley from supercharger.com.
gosu08
Apr 27, 2009 07:49 AM
sly_itr2001
Sep 7, 2004 10:39 AM
suprchrg95
May 17, 2004 01:10 PM
fredtoast
Nov 27, 2002 11:09 AM
1badITR
Jul 8, 2002 02:08 PM
